Manual Crank
Discussion in '40- & 55-Series Tech' started by Benji, Mar 8, 2004.
  1. Benji
    Benji
    1,087
    1
    Feb 12, 2004
    North Texas
    I am somewhat new to the LC world. When I first bought my 84 FJ60, the PO said the off-centered hole in the front of the grill was there so that the engine could be manually turned over with the OEM jack hand crank. He said it was fully functional, however, some AC parts got in the way from doing it. Is this mechanism still functional? Does anyone know about this, or did he just pull my leg?
    :cheers:
    Thans for the clarification.
  2. nuclearlemon
    nuclearlemon not an addict Moderator
    16,135
    Media:
    87
    Albums:
    4
    998
    Jan 30, 2003
    meh-ico, colorado
    yes, it is functional, just make sure that you don't lock your elbows when cranking. on the 60's, the radiator or support or something is in the way and you can't get a crank handle into the engine.
  3. Landpimp
    Landpimp GOLD Star
    15,932
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    he is correct, the notch in the lower valance is for the hand crank handle, he is also right in that the AC and or rad is in the way of the crank nut it need to hook onto. But if this wasn't there........yes yuo could hand crank it.
  4. cruiser_guy
    cruiser_guy
    11,197
    30
    Jan 20, 2003
    Wherever the truck stops!!
    I would rather get a jump start, push start it, try coasting down hill or any other solution before I'd try cranking an engine over by hand to start!
  5. lagwagon
    lagwagon
    1,061
    2
    Nov 22, 2003
    Loomis, CA
    I haven't seen any 60's with the proper crankpulley nut
