1977 fj40
2f no headers
Rebuilt carb 14 months ago
So I'm trying to track down a vacuum leak/exhaust leak etc. long story short, truck was running good, next day had to pull the choke to keep it running. Replaced engine fuse which helped a little (blown but couldn't see it with the naked eye). Replaced idle cut solenoid to rule that out. Testing with carb cleaner had small engine revs under the middle under the carb heat shield. Also sounded like at the base of the carb would slightly rev. The weird thing is what looked like smoke or exhaust that would come out from underneath the front and back of the manifold. And.... I could see exhaust seeping out between the coupled where the main exhaust pipe drops down.
My vacuum is around 12-13". Low right? I'm at 4000ft roughly.
So I decide to pull off the carb and manifold.
The rear bolt looked like a nightmare, but it was only on finger tight I swear. So I pull the whole thing out. Gasket doesn't look super bad. Looks to be some kind of metallic type.
Question 1 - is the front part of the manifold, supposed to be free turning? Does it need to be sealed better somehow? I'll try and post up a picture.
Question 2 - seems like when I put it back together with new manifold gasket, I could use the high temp gasket stuff along the block side. Does this sound alright?
Seems like I need to have the manifold side machined to a flat surface as well.
I also wanted to use the high temp liquid gasket to go I in-between the carb riser, and the carb, And in between the exhaust pipe that exits down.
Any other ideas or thoughts?
Thanks
Wyatt
2f no headers
Thanks
Wyatt
