Manifold Question. Please help
I desperately need a new exhaust manifold for my 1970 F Engine. There is a 2f manifold on Ebay. Is it the same as the one I am replacing. Please help.
The header I bought was the same for the F and 2F. That may be an anternative for you. I think the heat riser would be the issue between manifolds.
The F and 2F intake/exhaust manifolds are NEARLY identical. They will not fit together, however, because the heat riser bolt pattern is different. 3 bolt for the F, 5 for the 2F. Also, the EGR systems differ a little bit.
