clownmidget said:Steve, the Old Man Emu N73L/N74L has 11" of travel.
Geeze, on the ball arent you. Well almost, they have 280 mm of travel, which is about 11 1/32". You thought that 1/32" didnt make a difference didnt you!
The problem you will have with a 6 inch lift is the distance between the shock mounting points. The remote resevoir shocks never come with posts, you have to use a shock adapter, which is going to take up some of the space you have to mount the shock. What we are trying to achieve with these shocks is not maximum travel, but equal up and down travel. Even though there are shocks with 14 inches of travel out there, using the stock mounting points wont allow you to use the full 14". You will have tons of drop, but no upward travel. The only way to get around this is make the shock mounting points farther apart, which not everyone can do at home. We are looking into that as well, we will see what happens.
