Man-A-Fre knuckle rebuild kit ?
granite falls WA.
man-a-fre has a knuckle rebuild kit that is supose to contain all japanese gaskets and koyo bearings, it suposedly has all the seals felts ect. and you can get it with the wheel bearings and knuckle bearings for $169.00 wich seems like a pretty good deal but i have been burnt by them before on quality. has anyone ever bought one and is it any good, or should i just talk to c dan ?
does that include the inner and outer hub bearings, or just the trunnion bearings? if not, it's too much. i got all the kits (yes, i've done quite a few) minus the hub bearings/races for about $100. i've been buying the inner and outer hub bearings/races through work in timken brand for about $40/axle.
Ditto I got all my parts in town for less, Toyota for gaskets and auto store for timkin bearings and shims. It is always about a bill. If you have time you might search other online venders too.
Cruiseroutfitters has a real nice knuckle kit, under $100 but minus the wheel bearings(I get em local anyway)
Hey thanks guys, and yes that was with inner and outer wheel bearings and trunnion. i will have to PM cruiserdan and see how much for toyota seal kit. thanks again!
Just did the front axle today and I picked up the trunnion bearings and races (KOYO) for about $10 ea.
Did you find TR35As, or BR30303s?
The 30303 has a steeper angle and therefore loads the bearing/race interface much higher than the TR35A (which is the one that Toyota installed there).
Hard to find the TR35A most aftermarket sources. And this is the bearing that comes in the Man-A-Fre kit.
Mine are the EXACT numerical match to the ones that were there which I assume are OEM since I've have the truck for 15 years. Bought them direct from Koyo here in Guatemala.
