Any ideas?
Here's the scene. I have a loft, which is over a large room and a bathroom, in my shop. I am going to build a wall from the loft floor to the rafters, but I want to be able to remove a section of it so I can lift heavier things up with the tractor. This wall will sit on the loft floor and be nailed to a rafter. The main bay area has standard rafters, while the loft has scissor trusses for additional volume.
I'm thinking of just leaving out a 6' section of studs as this wall will be non loadbearing. In that section, I'm thinking of having basically a removeable "window" that I can tip back into the loft and slide to the side to allow access. I don't want it on hinges because the swing radius would cut out a lot of useable space.
What say the builders?
That would actually be perfect. I'll check to see if I can find a kit locally. The total height is only 67" from the loft floor to that rafter, so I'd have to DIY. The stairs come up parallel to the first scissor truss. Great idea, thanks Dan!
