I would be very surprised if the header doesn't need some grinding around the bolt holes and the lower ears of the intake to line up. Both the Downey headers I've used on mine have needed some modifications to fit. And it won't seal very well without that bolt either. I had to tap out a few of the holes larger in my head after multiple gasket changes stripped out a couple. I replaced all the bolts with studs&nuts, and I haven't had any issues (or leaks) since. Also if you are removing the air rail at the same time and just crimp off the lines instead of installing plugs, when they leak (and they will) it sounds just like a leaking manifold gasket. One of the best tools I ever bought for diagnosing stuff like this was a mechanics stethoscope. I'll bet half the manifold gaskets I have replaced because I thought they were leaking were actually cracked header tubes and leaking pinched off air fittings.
