For Sale [ma] Koyo Double Cardan Joints
landtank
Supporting Vendor
Groveland MA
Website
landtankproducts.com
I have 3 Koyo DC joints for sale for 50.00 ea. plus shipping.
There was a mistake made on the last batch of DC front drive shafts where the wrong joint was sourced,
These joints have a 2 5/8" x 2 5/8" bolt pattern and will fit the rear shafts in an 80 series and possibly other trucks.
This joint can be used with the stock rear drive shaft from an 80 series to make a rear DC shaft for that truck.
I am assuming they are new? No miles? Hmmm, I may be interested.
Rick,
Are these plug-n-play with the stock drive shaft or do they need to be welded on to a re-sized stock drive shaft? Also, how much is shipping to 92082?
Thanks,
Derrick
If your drive shaft has a straight tube all that should need to be done is to cut the tube shorter, weld these on and balance the shaft. Quite common for any driveline shop.
Flat rate USPS would be 15.00
I'll take it!
P.M. Sent
