Ok. I still need to jack it up. I can't get under the front with the suspension in H. So, I guess I need to flush it for the front to raise to it's max.
yep, all good. 5th accumulator won't fill until you raise to Hi.
you disconnected the fill hose in order to drain the reservoir?
This may be a wildly ignorant question but is the ahc designed to make adjustments while the vehicle is in motion? My 2011 rear end will go up when I’m driving and then drop back down very quickly at stop lights. Doesn’t always happen and seems to have a mind of it’s own. I’ve assumed it was suppose to do this? Can also sound a bit clunky when lowering. Any thoughts?
Normal. AHC is constantly looking to level the rig, it lowers into fast low if you go above 62mph, and it helps dampen the suspension while you drive (depending on the selected comfort setting).
What mods do you have on the rig?
Prior to adding a rear bumper, my front did most of the leveling, but now I feel the rear more. I also think my adjustments have gotten more abrupt since I've gotten so heavy. /Quote/
Good to hear, thanks. No mods, still bone stock.
anybody?
It's not a 100, so there are different metrics.The 100 series people sent me here. Could not find a dedicated AHC thread, figured this is the best place to ask for advice
Hello fellow mudders. Insurance totalled our GX 470, and in a couple of days she will be gone. We had very good memories with her. Got at 150,000 miles, and now gone at 220000
Expense was OME lift kit and then a ARB bumper after a deer hit.
Very reliable and solid.
Now for an upgrade, we did think about a 2016 Tundra due to space to carry stuff like telescopes. But then lack of dust proofing (even with a cap) and insane 38K+ prices put us off.
Along cames a LX 2011, around 150,000 miles done. Seller is asking 28K.
I am wondering apart from pulling the carfax/Autocheck (I just need VIN I guess), what else should I check.
Things I should do...
1. 14 clicks from L to H. Or above 10?
2. Check fluid using a straw. Should be pink
3. Shocks and springs, what to check?
4. Rust of course
I have techstream. What should I check on techstreaM?
