Hello,
I have a passenger side floor leak go on a month now. The floor board fills up with water after a rain or a wash..... Puddles to front outer kick panel area at front of door at footwell area..
Trouble shooting:
1). Checked hood cowl area by wipers: removed it all cleaned it up. Nothing there. Put it back together.
2). Checked all passenger side door seals...intact! No tears or smoking guns.
3).Checked sunroof after extensive panel removal.......rt front drain tube intact and patent. Torn off more paneling , a pillar, no leaks hose was tight at upper connection.
4. Windshield check.....couldn't figure out any thing special.....wasn't sure what I was doing. I figure it was a botched job, but all was sealed up to my inspection.
5). Did do Mud search.....all pointed toward. Sunroof drains...
Hmmmmm....
After all the tear out panels on the truck I closed it up and hosed her down...and inspected.
Found the leak!!!! Kind of....
Noted Rt passenger side kick panel area with leaking above the computer brains up in a closed channel portion behind the fire wall where the door bolts to the frame.
Seems to be leaking down or around the lower portion of the sunroof drain inside the kick panel area.
The odd part is I can see everything except in the closed channel area about of ~ 1.5 feet......no leaks at the windshield bottom..(top hose area below windshield). I can clearly see the tube there just before entering the channel.
Something is happening in the mystery zone of that 1.5 feet...
I'm concerned of a busted or cracked hose b/c no water at the top under the windshield, but there's water leaking about at the above the distal end of the hose....
Water runs freely through hose and out of the channels in the front frame.
Possible another hose connection that may be loose in the mystery zone?
Some wierd missing bolt allowing water entry?
Wonder what I'm missing???
Should I just gut the entire hose and replace it?
Reseat the windshield?
I see cussable moments ahead with that endeavor....
Any insight appreciated.
Thanks,
Todd H.
Trouble shooting:
Hmmmmm....
Thanks,
Todd H.
