LX470 Fog and Turn Lamp Wiring Map to ARB Deluxe Bullbar (03+) Fog and Turn Lamps (1 Viewer)
OwnerCS
GOLD Star
USA
I'm trying to map ARB bumper Deluxe Bullbar (03+) fog and turn signal lights wiring to my 99 LX470 wiring harness.
Hopefully, once I figure this out, it can help someone with this installation.
Here's a map of the ARB colors to LX470. Can someone verify this is correct? I will update the mapping image with any corrected information.
Also, since the LX470 turn signals are only turn signals and not a combo parking/turn lamp like the LC, are one of the wires on the ARB lamp unnecessary?
I just got off the phone with ARB about the Turn Lamp wiring. Here's the information and updated map from the call about the Turn Lamp wires.
Red - Parking (+)
Black - Ground (-)
Green - Turn (+)
LX RH Wires
LX RH Wires
ARB Fog Light Wires (White-Black) and Black
ARB Turn Lamp Wires
NH
Here's a (DRAFT) map of the ARB colors to LX470. Can someone verify this is correct? I will update the mapping image with any corrected information.
LX RH Wires
LX RH Wires
ARB Turn Lamp Wires
Everything looks correct. The green wires on the ARB turn signal plugs will be spliced into the OEM turn signal harness.
OwnerCS
GOLD Star
USA
Thank you for responding. Basically, merge the Green ARB turn signal wires with the Green OEM (ground) wires?
NH
IIRC yes, that's what should work. I swapped over to a LC front end and rewired everything, so my wiring work is a little different than OEM. If you check under my profile you should be able to find the thread I posted about it, and a couple pictures are posted that may be helpful. I can grab some more in the morning with better detail.
OwnerCS
GOLD Star
USA
Thanks again!
OwnerCS
GOLD Star
USA
This afternoon I talked to an ARB representative and got the Turn Lamp wire mapping. The first post is updated with the information.
