Hi all, hope I help some others here with this same problem I just took a couple days to solve. So my AHC wouldn't go into high, it would flash twice and then go back to N. However it would go in and out of Low with no problems. On the dash the VSC lights and VGRS light were on. Another symptom was the driver door lock barrel wouldn't lock the rest of the car, just that door. Anyway the problem was as simple as the ECU-B2 10a fuse in the driver (RHD Model) kick panel fusebox. After replacing this, lights disappeared and AHC worked perfectly. Also the doors would all lock when locking the driver door.
Hope this helps some other beginner like myself when coming across this problem!
