Hi folks, long time reader here (although only just registered), great post on suspension that fixed Bucking Bronco issue and replace my accumulators (saved me $$$'s).
So my 1999 LX470 cranks but won't start (250K miles). Symptoms are as follows:
- Has intermittent start issues, but not won't start 100% of the time. (past issues difficult to diagnose due to location/other drivers own household)
- When key inserts/security key light on center console does not stop flashing
- Tried with a second key, it still does not stop flashing
- Check wiring around the ignition column/switch and any wires loose to amplifier/coil
- Inserted scantool, fails to establish a link
Things tried so far:
- Check all fuzes on the engine compartment fuse box and the foot well fusebox. Nothing is blown
- Read thread on crank/does not start and the fuse bypass. Have jumped /bypassed the fusebox for the main relay in case I have the fusebox issue. No change in symotoms
- Pulled the main relay/tested - no issues. 12v in input causes audible click and open changes to 0ohm on output
- Repeated the same test for both IGN1 & IGN2 relays. No change of symptoms
- Pulled the Engine ECU from behind the glove compartment (I tired to buzz out power but don't have the right wiring diagram)
- With Engine ECU out, still unable to get a link from the scantool (does this mean another ECU on the scan bus is killing the link?)
- With Engine ECU, did a visual of the circuit board, can't see anything obvious.
Any other suggestions? Wasn't able to see where the key ECU, supposed to be up above the Enginee ECU?
