- Thread starter
- #21
This is what I used. Was on the shelf at walmart.
@JLH911 I ended up making the same harness and you can just tape up the RCA connections if you like. I cut mine off for space.
In short the RCA plugs are just not used in this configuration.
It won't make sense to you until you yank out your amp and original head unit. If you just went to walmart and picked up the wiring adaptor for Toyota(Scosche shown above) you would find the plugs don't work behind the stereo at all. However they would connect in where the amp is located behind that right dash speaker. the Metra kit that is needed for the LX assumes you are going to use the amp still (which no one seems to get working well with after market headunits). So you are chopping up the two kits indicated above and lengthening them as well as including the wiring harness from your new after market headunit. Look in the picture above you can see the top plug has some bundle of wires that are just cut in a heatshrink tube. Those were RCA connections previously that I didn't use and cut off.
Thanks. Yeah, once I enlarged the picture and put my reading glasses on, I could see that the harness had the RCA plugs cut off. It makes sense now.
I know there has been a lot posted about this but after spending a lot of time reading through a bunch of info I was somewhat lost in misinformation and discrepencies. I accidentally came across a really easy way to wire an LX450 aftermarket deck so I thought I would share the info for anyone else searching for info.
My method requires no cutting and splicing of the already short AF factory wiring. This is a plug and play method with minimal running of wires to bypass the factory amp.
You will need one Scosche TA012 and TWO Metra 70-8112 wiring kits or suitable replacements. You will also need approx 8' of speaker (2 conductor) cable and a pile of red butt splices
After removing the factory amp from behind the passenger side lower dash speaker, you will have 3 plugs that were plugged into the amp. 2 of the plugs from the TA012 are used and one of the Metra plugs is used. Match up the wiring color for color and extend the left over speaker wiring to your deck harness speaker wires. On the deck end, just match color for color. The RCA plugs on the Metra kits aren't used (I chose to cut them off, taping them off is unnecessary as they are only connected to dead end wiring in the vehicle harness)
I put this all together by accident and it worked! The power antenna works with the deck and the deck lighting dims with the headlight switch as it should.
If these pictures were labeled that would be amazing.
On the LX one goes to the CD changer. You need to look above at the directions on how to bypass the factory amp which is behind/to the right of the glove box.
I had success! Made this up to help explain to people. IF YOU HAVE the extra unused plugs behind the factory stereo (many LC do) then you can JUST use the Scosche TA02B adapter. If they aren't there, to bypass the amp you need more.
