LX450 Locker?
Lee's Summit, MO (KC)
Test drove a similar LX450 to the one that is being shipped to me today. When I put it into 4lo a "dummie" light came on in the dash that was amber and said "DIFF LOCK" Now this LX450 did not have the factory locker toggle switch on the dash, so I am confused as to why the truck was telling me something about the diffs and being locked. Anyone have insight?
As Sammy said.. CDL. All LC's/LX450's are equiped with a center differential lock, which is engaged when you shift into 4-lo (unless you've done the CDL switch/pin 7 mod. that is).
:beer:
Rookie2
Yup,
that jsut means it is working as designed.
the center diff lock will engage in 4 low unless you tell it not to with the pin 7 mod.
search for pin 7 by author cruiserdan back 500 days and you will see some cool stuff.
Dave
All LC/LX450's have a center diff lock. The front and rear lockers were options from 93 on and they will have the rotary switch to the left of the steering column. In 91/92 models they center diff does not automatically lock and use a dash switch above the radio for that. That same switch can be added to the 93 and up to allow manual control (not supported by Toyota) and therefore as the other posts have referenced the pin 7 mod.
slight correction.
the 91-92s center does lock automatically in low it just has a swithc to lock in while in high. this switch can be placed on the 93+ models as well to lock in high.
little point but one worth making.
Dave
Phaedrus, you beat me to it. You cannot run in low unlocked on a stock 91-92 80.
-Matt
Yeh, step-bro. Truck is here and running. Just have to get plates on it so I am legal. PO didn't ship the plates with it, so I had to through on my old PA Truck license plate so as to not raise too much suspesion. Prob is, here in TX you have to get the truck inspected and then take the results to the tax office for your registration and tags. That anin't gonna happen right away. So I will behave and stay under the radar.
