I tested my hand held CB against the Cobra in my 40 and it only worked about two blocks. Not very releable for something I may need to use if I break down, or if NorcalDoug drops his Pink Panties at Moab and I need to let him know.
I Bought a Cobra 18II ?, The one with 40 channels and 9 weather channels. It's the same one I run in the 40 and I have been pretty happy with it.
So now comes where to put it. I did a search and found lots of folks have replaced their radio and use it in one of the slots. I still have the OEM radio, so that won't work. Lots of the old links with the photos for their installs don't work anymore.
Under the steering wheel looks like it would block things and be in the way.
So, I started thinking about between the console and the drivers seat. Any one install one there? Lessons learned like don't becaus it will break the console.
Maybe under the dash on the Passenger side?
Next I have to try and find a 4 inch antenna with a Pivot like Nakman's so I can put it down across the ARB when I am not using it. Anyone know were you can get those. Nakman's PO put it on and he doesn't know. It's a nice set-up if you haven't seen it.
Thanks
Ken
Thanks
Ken
