Hi All,
This thread is for replacing speakers in the Lx without removing the entire door panel or in the rear the plastic / vinyl quarter panel.
My front 6.5” ML went in 2017.
I removed the speaker covers and cut out the speakers.
I found some good quality 8 ohm speakers on Amazon
They have been good speakers, the magnet was way larger than the ml they replaced. They sound better, for sure.
I basically created “backing” for small screws to re-attach the OEM speaker covers with. I drilled holes in each corner. I think they look good. Not stock, but stock is overrated.
I just don’t have the time or inclination to remove the whole door panel.m, to replace a blown speaker.
Call me old school but speaker covers should be just that. Removing the entire inner door panel when a speaker cover is right in front of me seamed crazy.
I recently did removed the rear drivers side speaker cover to replace the blown 5.75” sub
(I know how can a sub be 5.75”)
I read that they can be fixed, I found a shop that does speaker repair all after 2 electronics shops said they couldn’t do it and I should buy a new one.
It cost $60 + tax = $67 Canadian about $55US
It went back smooth and sounds good. I actually had to turn the bass down.
When I removed the speaker cover in the back I ripped the fabric, but I’m not bothered by the look.
I did break the factory plastic, but the small screw holes I drilled worked fine to hold the speaker cover on.
