LX Projector Pattern
Orange County, CA
I’m trying to figure out if my headlight pattern is abnormal and just needs replacement or if this is normal.
In replacing the stock bulbs with LEDs, I noticed two areas where light way bleeding above the cut off area.
In the photo, I have one light with the factory bulb and one without. As you can see, even the factory bulb has a faint bleed but the LEDs make it much more noticeable.
Perfectly normal, search this forum for “squirrel finders”.
LED projectors are different from halogen projectors due to the completely different way light spreads from the two different bulb designs.
When adjusting the projectors, whatever kind, this is from the FSM for the LC/LX. Adjusting the patterns at the distances specified here makes sure that they won't throw glare further away.
It asks for thick white coloured paper, but I just park on a level ground against a wall or a garage door and mark the positions with electrical tape.
