Not completely done yet, but here's a sneak peak of the onboard air project for my LX. Different take than the usual beastly dual-arb underhood. My original intent was just to get a portable Viair unit with gater clamps. Thing is, the LX has engine bay covers EVERYWHERE, even over the battery/batt terminals. I needed something because airing up for an hour after off-roading with a cig lighter type unit is a no-go.
New direction was to hard mount a larger Viair unit. In this case, I split a dual pump kit, continuous duty cycle Viair 444C unit with my brother. Basically a 450C pump but physically larger, bit faster, and 200psi capable. This is a high quality, rebuildable, fully sealed from the elements (IP67 rated), air tank style compressor. What it lacks for immediate speed, it'll make up for in pressure and volume with a little tank. Which should prove to be just as fast as most anything in use, and also have compressor type functionality. (EDIT - if not fitting an air tank, I recommend the smaller but faster 400C)
It's a large unit. I mounted it directly on top of the crashbar to keep it away from engine heat. It's breather and air coupler will be mounted away from the front to keep those out of the elements. I would have preferred it not be bright chrome, but it'll be discrete enough.
On the LX, the grill comes out relatively easily and it's wide open access with more than enough space to install it.
EDIT: $246 Parts List here - LX gets Onboard Air
