Pretty sure they fit in the back, might need to tap with a drift on hammer if not stripped out..Got one/two lug nuts that don’t seem to want to torque down. What would cause that? Nut stripping? Stud stripping? Thanks
That’s pretty much it I think. I would pull them off and inspect the threads carefully while you can, if they get too damaged it might be difficult to remove them.Nut stripping? Stud stripping?
I’ll double check them with one of those thread pitch tools tomorrow. Or maybe the mating surface of the wheel hole is out of round or not same size anymore?That’s pretty much it I think. I would pull them off and inspect the threads carefully while you can, if they get too damaged it might be difficult to remove them.
