Just thought I would post up some positive smog news for once.
It's CA smog test time again from my 1985. I was a little concerned because two years ago I was right at the limit for HC. This morning I replaced a couple of exhaust gaskets to fix a leak, and drove to the station to get a baseline test.
An EVAP test is now required for vehicles '95 and older. They checked it off on my test result, but from what I saw they didn't have a cap that would fit my filler neck. Two years ago this station had one, but they must have lost it.
A few more minutes go by and the guy comes back and say's "you passed". I commented that they didn't do the dyno test. He said they can't do a dyno test because it's a four-wheel-drive vehicle. I've had three previous dyno tests at this same place. I guess they forgot the difference between part-time 4wd and AWD. But I learned enough in school to know not to argue about a passing grade.
And my results:
Idle:
CO2%: 14.10
O2%: 0.60
HC ppm: 96
CO%: 0.08
2500 RPM:
CO2%: 11.7
O2%: 3.90
HC ppm: 85
CO%: 0.04
Good luck to those of you also getting tested this year.
And my results:
Idle:
CO2%: 14.10
O2%: 0.60
HC ppm: 96
CO%: 0.08
2500 RPM:
CO2%: 11.7
O2%: 3.90
HC ppm: 85
CO%: 0.04
