One thing you can try if the slip yoke is overgreased is to remove the zerk, then drive up & down a curb or 5mph speed bumps. If there's excessive grease in there, it should ooze out.
If the shaft hasn’t been lubed for years, it takes a lot more than 3 pumps.isn't there a fitting you have to remove to alleviate the pressure normally only 3 pumps is recommended
agreeIf the shaft hasn’t been lubed for years, it takes a lot more than 3 pumps.
remove the zirk at the base with 6 or 8 MM , anyone familiar with the exact size. If u joint only took 3 sounds like it was regularly serviced
should be basic
7mm..I opened up the zerk and saw the green grease but nothing spilled out. I jacked up the rear 20” but nothing...then lifted the front with nothing extruding. Lifting it didn’t seem to compress the slide joint - note it is still in “N” drive
Is it possible that it was empty and is still not full after 20 pumps?
I’ll keep the zerk open and drive it a few miles tomorrow
