Lsvp (1 Viewer)
Bakersfield, Ca
After i installed longer shackles and aals, my cruiser will pull to the left under braking. I was wondering if i need to adjust the lsvp? I am not sure what it does but know that i probably need to adjust it. Thanks
Big D
You need a front end alignment.
New Kent, VA
More than likely you need to adjust the rear drums, lifting a solid axle truck doesnt do anything to the alignment.
Bakersfield, Ca
Yeah i dont think it is an alignment issue, it drives straight, so do you just use a screw driver and tighten them till the tire wont move then back off a little? No adjustment to the lsvp?
New Kent, VA
You can adjust the lspv, but that has no relation to side to side brake bias, just front to rear.
