So parts guru needed or a lead on one I can call.....just got home from overseas.....all excited to take the LC down to get the exhaust worked on....aaannndd the brake light came on and it turns out my driver rear hardline on the axle where it is mounted at the first clip and the LSPV both blew up and spewed brake fluid all over the cul-de-sac. Luckily it was there and not the highway and good thing I pump my brakes to check them before I drive anywhere. Anyway, short on time. I want to replace the entire LSPV "system". The local parts guys are not helping me as on the schematic it shows two non-descript "packages" and isn't really clear on the contents.
On the schematic it shows the valve itself:
Valve Assy, Load Sensing Proportioning
47910-60090
Then these two guys, which both show the boots but have other misc. parts:
Bush & Boot Kit, Load Sensing Spring
04477 (04477-60010)
Spring Assy, Load Sensing
47920 (47920-60090)
The intent is to replace EVERYTHING (shackles, bolts, nuts, I do mean EVERYTHING on both ends). It seems that 2 of the bracket pieces are NLA, but I may be able to salvage them. It shows the shackle and other misc parts in those kits but again no one knows. They also have the parts listed seperately. My LC has light/moderate rust except for some reason this entire assembly on both ends looks like rust califlower. I don't know what these "kits" include and what would be needed other than what is in them. Since seeing the price on the hardlines I've decided to just replace all of them and the rubber lines as well.
If anyone in the Virginia area has one of those SST's for adjusting this thing per the FSM, I will gladly rent it from you!!! Or anyone willing to mail one........I only have about 10 days to get this beast road worthy again and I have to go back out. Any help is greatly appreciated!
47910-60090
04477 (04477-60010)
47920 (47920-60090)
