No way was mine moving anyplace. Nuts come off OK, the the vavle and the plate are fused as one, rust welded together.
Took the rod off at the valve end, and boot off, and had the
start then engine and apply the brake; I could see the range of travel of the nipple in there - only about 3mm (1mm out under no pressure, ~4mm under pressure)
Made up a little brass button, OD a snug fit inside the circluar form of the guide that fits around the nipple (it has a slot to allow the rod to pass up and down it). I went for 3mm as I'm planning on reducing my rear lift - my supposed 2" springs are more like 3.5". Longer would actually work better in terms of stability within the channel. Time will tell how it goes, will sort the suspension before I do the lockup test, but I really can't see why it won't work.
Thoughts welcome.
Rgds - JB
Thoughts welcome.
Rgds - JB
