LSD on 80
The GXL and Sahara in Aus both come standard with a LSD in the rear unless you order factory lockers
My LC has LSD in the rear and open diffs up front. I had the impression that it was standard fare.
A simple way to test if you have LSD is to lift the rear and turn the wheels by hand with the gear in neutral. If both rear wheels turn in the same direction you have LSD.
Kalawang
My HDJ-80 (fulltime) came with a factory equiped LSD ... which can be adjusted to be less bias ... in my case the diff housing had a sticker that reads LSD :doh: facing towards the rear
