Ls swap radiator and hoses
Would you happen to remember the part numbers for the hoses you used?
Which hoses? I didn't write down my hose numbers for everything (I should have), but I could go out and see if I have any numbers visible. For most of them I just went to the auto parts store and started looking for the bends I wanted.
Both upper and lower if possible.
Unfortunately, the website that used to host my build took a dump, and all my info like this disappeared. However, I do have a little info for you. Upper hose is a Gates 20450 (just the 90* bend part) to the JTR adapter. Then it's a 18" Gates flex hose with a 1.25" opening on one end and a 1.5" on the other.
zTIalv_e5-y4ymoju_tPWs-PbDgx6Z_1cZ2DK91uawiKlTGCXTM93kjnJXwkPeNcFnDKduCR_cFGMIaEMeOuZ3zUknLSfICPmYVWw6SlHRBpcfkuw6h5Sq_gxHAbcf1T_dl46cuoOk0=w2400
For the lower hoses, I don't have the hose numbers. I believe they are both 1.5" inch openings. Basically, I went to the parts store and got a hose with a 90* bend and a hose with a 180* bend. Then I connected them with a 1.5" "radiator hose repair kit" coupling. Not the best photo, but here you go.
WPTvrPwZeUnJijs9dGxUR7yzb_Ah8baNyOYohsl39PY4Ogms-5Er_05K7yHx_iv9LpggBuTiY4UZTWy98fVyI2ElLXYjqZXVDSTEWKX4kmwTqldgyUcWuhKYUzdqcDXxJTYe2UVrT3k=w2400
Hope that helps. It's not the cleanest setup as far as hoses go, but it works for me. After a couple of years, still no leaks.
I spent a good part of today looking at various auto parts stores to get close to what you have. The only difference is my radiator has the 1 1/4 at the top. Other than that I was able to "match" what you did....just waiting on the metal barbs that join the pieces to get here. I really don't care what it looks like as long as it doesn't leak!!
I used a custom Griffin radiator in my latest FJ45 conversion. It is a 19" x 27".
Engine is an LQ4 (6 liter) and I use the stock fan.
I asked the great folks at Griffin to include ports for the oil cooler lines (blue) and the Vortec steam port.
Even without a shroud, this radiator does a great job. I have a tranny cooler sitting in front of the Griffin, and have no heating issues. Lil'John's hose numbers should work with this setup.
what hydoboost unit did you use ? disc front and back?
