As do I, I wished I started using it years ago! The bang for buck instant power increase this provides is seriously underrated within the diesel/4wd world. I can drop my EGT 200 degrees near instantly when I activate it and the added performance increase is great.I prefer using methanol injection now. It drops EGTs while boosting power. Propane does not do much for lowering EGT. Modern methanol injection systems can be programmed to come on in stages and can be a lot easier on the tranny...
Comp wheel erosion can be a serious concern on poor system setups with no safeguards in place. It's also one of the main reasons I went for the highest pressure pump I could source as the higher the pressure drop at the orifice the more effective the atomization nozzles are and the smaller the droplets. Most people think the damage occurs when the injection is activated and spraying water into the comp wheel but this is incorrect and if you've ever seen water injection been sprayed into a turbo which is on boost you'll notice it gets sucked in kinda like a vortex into the centre section of the wheel only. Most pre-turbo injection damage occurs when the nozzle activates/deactivates and some dripping happens which then moves along the wall of the intake and hits the blade tips on the outside edge where the tip speed is highest and as solid liquid. You can imagine that each time the nozzles activates/deactivates a few drips occur and it doesn't take long for water to start pooling in the intake elbow which eventually makes it way to the comp wheel tips causing erosion. I have solenoids directly attached to the nozzles which eliminates any chance of water still in the lines going to the nozzles from dripping out. Also even when my system activates the pre-turbo nozzles my solenoid still won't energise until I have reached a preset system water pressure which also prevents any initial dripping or poor atomization occuring due to low water pressure as the pump turns on and builds pressure.Initially I had a small nozzle pre-compressor on my engine also. I got scared of possibly eroding the compressor so removed it. Maybe the droplet size is reduced enough with the higher pressure systems (like yours) this is not so much an issue. With the little pre-compressor nozzle, I did not notice much performance improvement on my system though... Not sure why. I do have a very efficient air/water intercooler, so maybe that takes away some of the advantage of chemical intercooling.
so im not up on meth injection, but its very intriguing to me and my 13BT. Not a lot of room for intercoolers on the 13BT with A/C. I was thinking about A2W, but I still need a heat exchanger and then pump/coolant setup.
If you want to use it in place of a regular intercooler, you'll need a big reservoir. So either you try to fit an intercooler, or a reservoir.
RIght, there always is +/- to cooling.
A/A = hard to find room for piping/exchanger
A/W = easier to fit, deal with smaller exchanger/pump/hoses
Meth = need a huge tank, always need to fill it, freezing temps = more methanol
A2W maybe the best setup for size restrictions. The only real worry is internal failure of the cooler pushing coolant into the engine, not sure how probably that is? And a small barrel intercooler, not sure how well that would cool in place of crossover.
