Lowering Ride Height Using AHC
Discussion in '100-Series Cruisers' started by mscott, Jul 25, 2005.
  1. mscott
    mscott
    94
    Jul 14, 2005
    Raleigh, NC
    Has anyone ever lowered the vehicle for highway driving? I'm wondering if you can impact fuel efficiency. Maybe wring another mile out of a gallon. Anyone?
  2. e9999
    e9999 You want to do what...? Moderator
    16,737
    593
    Sep 21, 2003
    US
    thought I read that it goes back to some default setting if the speed exceeds some lowish value?
  3. hoser
    hoser SILVER Star
    9,031
    1,291
    Dec 21, 2003
    Bay Area, CA
    It is possible to "trick" the system but keep in mind, when you lower it almost 2 inches, there will be a change in your front alignment setting. You'll have also lost 2 inches of suspension travel.
  4. Jim_Chow
    Jim_Chow
    2,479
    14
    Apr 28, 2003
    Turquoise Trail, N NM
    I've seen JDM AHC controller units that allow one to raise/lower the suspension in 10mm increments while driving or stopped. My main concern would be the CV joint angles/wear. It is correct to say that when the AHC is raised, all the load is off the t-bars, and, therefore, the CV joint angle increases beyond what is optimal for maximum durability?
  5. ace10
    ace10 Another one bites the dust! SILVER Star
    808
    Media:
    15
    Albums:
    2
    274
    Jun 24, 2004
    Rural NoVA
    why would you assume that lowering a vehicle would improve it's fuel efficiency? it's the same weight and the same frontal area.
    it's a 6K pound, fulltime 4wd, barn on wheels.
    my top-of-the-hat to fuel economy is the removal of the worthless roofrack crossbars. it's a bit of work, but they're certainly not being used and cannot be good for slipping through the air.
  6. mscott
    mscott
    94
    Jul 14, 2005
    Raleigh, NC
    That's my point. It would not be the same frontal area. The height would be reduced by 2 inches. In addition, I believe (possibly incorrectly) that the lowering of the vehicle would better direct airflow around and under the suspension.
    I'm not concerned about the loss of travel, because I'm only traversing the pebbles and pot holes on the highway...
    I agree, its a barn on wheels, and I love it. But, if I'm on a 600 mile road trip on major interstate highways, I need every bit of fuel efficiency I can sqeeze! If I can get it by using a built in function of the vehicle, I'm gonna explore it.
    Anymore thoughts?
    -- Mike
  7. hoser
    hoser SILVER Star
    9,031
    1,291
    Dec 21, 2003
    Bay Area, CA
    Sure, maybe... but just so you know, here is a picture of the suspension fully lowered. I couldn't fit a finger in there--it is less than 1/2" at the bumpstop. 1/2" at the bumpstop is probably just over an 1" travel at the wheel. Maybe somebody can calculate that. At normal ride height, there is over an inch of clearance at the bumpstop.
  8. mscott
    mscott
    94
    Jul 14, 2005
    Raleigh, NC
    Great point hose. Thanks for the picture. I wonder if I'd also need to consider changes in suspension geometry since we'd be talking a lot of miles in that configuration... Wouldn't want to destroy the tires w/very uneven wear.
  9. LX_TREME
    LX_TREME
    2,645
    11
    Nov 16, 2004
    Pasadena, CA
  10. HDJ100L
    HDJ100L
    233
    2
    Mar 1, 2005
    Philippines
    hello,
    this is the unit from bblanks. it bypasses the AHC to lock the height either high or low. check it at www.bblanks.com :)
  11. ndcruiser
    ndcruiser
    165
    1
    Aug 1, 2005
    Bismarck, ND
    I'd be more interested in raising the ride height. I read somewhere it could be "fooled" into staying up there, do you need aftermarket equip to do it? I'm also wondering about the driveshaft angle, unless it was designed to compensate for it.
    John
  12. hickok
    hickok
    218
    Jul 10, 2003
    bblanks system
    Does anyone have a system like this in the US for sale?
  13. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,939
    Media:
    79
    Albums:
    4
    3,018
    Mar 6, 2005
    Mauldin, SC
    A touareg when it is over 60 mph it will lower for better fuel economy. Will also dip the front for better viewing and servicing when the hood is open. Maybe a few tricks Toyota could add. Also has a 4x4 mode to encrease ground clearance by 2 inches.
  14. hoser
    hoser SILVER Star
    9,031
    1,291
    Dec 21, 2003
    Bay Area, CA
    The BBlanks post above you is what you need. There are others that are cheaper that don't use the factory controls. You will also need to get an alignment job and will probably want to get a drop down bracket for the front suspension. There will be no problems with the driveshaft angle.
    I don't know anybody in the US that carries the BBlanks AHC control but I was thinking about ordering one from Japan. The price is about $350US plus whatever costs to get it here.
    Christo is working on a blackbox that will do the same thing. Not sure when it will be out but I don't think it will be available before summer's end.
  15. hickok
    hickok
    218
    Jul 10, 2003
    Christo -
    Any scheduled date we should start seeing the black box for sale?
  16. LX_TREME
    LX_TREME
    2,645
    11
    Nov 16, 2004
    Pasadena, CA
  17. hickok
    hickok
    218
    Jul 10, 2003
    bump
    Just wondering if anyone is importing the bblanks adjustable system or does Christo have his AHC just about finished?
  18. hickok
    hickok
    218
    Jul 10, 2003
    bumpa-dee
    Am I SOL?
