Lowering Bump Stops FJ40
Vancouver, Washington
What do you recommend! the tires are up into the wheel wells. I have trimmed my fenders, my back axle is moved back about 4" . The tires are going up into the wheel wells and it's tearing up the tires. What length do you recommend? Need some help. Thanks, Scott
stock bumps simply bolt on....you could simply pull the two bolts, and add in spacers/washers to add the length you require, with longer bolts.
