Lower Tailgate Handle
Tampa
This information may seem trivial to some, but I figured I would pass it along just the same.
I broke the plastic release handle for the lower tailgate. I just wanted to drop a note stating that Toyota redesigned the screw that joins the handle to the stud. The original was a countersunk type that almost appeared to have acted as a wedge and cracked the original handle. The redesigned screw has a flat ridge on the underside so as to not apply any outward force on the circular handle opening.
P/N:
- Handle, Back Door, L 69212-60030 and the
-(Redesigned screw) Screw 90149-50064.
Do you have a part # for the upper tailgate handle? i bought my lx a year ago and it was missing.
My handle was cracked and I purchased a new one recently to replace it. Thanks for the info!
Russell
The part number doesn't really matter.
The early number that uses the countersunk screw has been replaced by the later version. There is a set substitution that tells the dealer that a new screw is required.
If your dealer has all his s*** in one sock you will get the proper screw as well.
D-
