I recently did my front brake pads/rotors, lower ball joints, and repacked the wheel bearings on my 1999 LC.
When I come to a stop (1-5mph), I can feel the brake pedal pulsing and what sounds like ABS activating. I have no ABS lights on. I'm a bit lost as to how to proceed.
So far I've cleaned out the front sensors again, and checked the ABS rings, which seem in good condition. I followed FSM for wheel bearings, and I double checked that they are tight (14lb preload). I've haven't been able to spot anything loose or incorrectly installed.
My question is could a bad wheel speed sensor cause this even though I don't have a ABS light on? Also, is there a way I can disable ABS to ensure that this is an ABS issue not something else? I don't want to start ordering $200 sensors before I'm sure it's the issue.
