Hello, first post here, after a lot of reading. I can't find anyone describing exactly these symptoms, so here goes:
Vehicle is a 2000 UZJ, 233k miles.
The center diff lock works when the switch is operated, and the corresponding lights for this and the disabled VSC illuminate. This works in high or low range.
When low range is selected, all the big stuff seems to behave normally, but nothing illuminates. In addition, the center diff remains unlocked and (I assume, didn't want to check where I tested the rest) ABS function is unchanged as well.
I don't know what mechanism tells the car when it's in low range, but I'm thinking there's a problem with mine. Where to start?
EDIT: This car doesn't seem to have much of an offroad history. It's from Santa Barbara and the underside is very clean, so I don't think any POs modified the wiring to behave like this.
