CaptHamster
TLCA #19645
Experiencing a really obnoxious low-pitch resonance in my FJ62 that starts at 65MPH . Lots of work done to the vehicle recently, which I will list below:
- H55F swap, transfer rebuild and rear driveshaft from Georg at Valley Hybrids in April of this year (4 months)
- BFGoodrich A/T K/O2's in 33x10.5x15 on stock wheels, mounted ~2K miles ago, recently re-balanced by local shop
- Knuckle job done 2 months ago with Sumo Gear kit, replaced one front axle spindle (driver's side), was damaged by overtightened bearing / water intrusion into hub (oops)
- 4° axle shims on rear axle, pointing pinion downwards; this made very little/almost no difference, debating removing them
- Old Man Emu deluxe heavy kit, done about 2-3 years ago, a little saggy now but still makes truck a little higher than stock
Not much vibration felt, whatever it is just makes the body resonate in such a way that it actually kind of hurts my ears. Below 65MPH, it slowly diminishes and is totally gone by 60MPH. I've tried speeding up past it, got to about 90MPH and it wasn't as bad but still present. Have tried clutch in, neutral and engine at idle speeds, still present, which leads me to believe it's driveline related. I can't imagine the recently refurb'd rear driveshaft is out of balance. The only things I can think are rear axle bearings or pinion bearing, all of which are factory original and never replaced.
Just want to make sure my thought process is right before I go throwing even more money at this thing trying to get stuff balanced right!
Also, recent pic included below, have to pay my IH8MUD taxes somehow
