Zjohnsonua
I hope this doesn't end up as another dead end low idle speed thread, so here's to hoping the 1FZ gurus are feeling chatty.
I'm working on a '94 FZJ80 (~260k miles) which my dad bought last weekend. It made the 9 hour drive home like a champ; albeit it had a low idle speed throughout the trip. Now it won't idle unless a touch of throttle is applied at start, but will drive normally otherwise.
Work done thus far:
-VAFM checks out to FSM.
-Unplugging O2s before starting doesn't cause any change.
-Unplugging the IAC before engine start causes the predicted wide RPM swings after starting.
-Unplugging IAC after engine start causes no change.
-IAC ohms out to FSM in all circuits.
-TPS ohms out to FSM.
-Spot spraying ether over the vacuum lines, around the valve cover seals and bolts, and around the brake booster didn't excite anything.
-Hose from VAFM to TB was replaced by PO (still sprayed ether at joints, no change)
I'm hoping the DMM can be used for a few more things before swapnostics gets involved.
Any hints? Thanks in advance, everyone.
Work done thus far:
