1993 FZJ80
I was chasing a misfire that ended up being a bad #6 injector, but in the process I did all sorts of work:
-removed PAIR system
-relocated O2 sensors to old PAIR location on manifold
-cleaned throttle body
-replaced spark plugs
-replaced distributor that had oil in it
I'm thinking I didn't put something back correctly when I replaced the injector, but now I have a low first idle - 800 rpm when it used to be ~1500 rpm. Also, it has an occasional hesitation when starting from stop.
I know I had to remove the throttle cables to get to the intake manifold. When I put them back, I adjusted them per the FSM. Does one of those affect first idle? I thought it was controlled by the IAC valve. Thanks for any help.
