87 fj60 - PO installed an H4 headlight upgrade - new harness with two bosch relays, install looks tight. The low beams are out - I have power to the relay, i hear the relay click, and when I "jump" the lamp the lights come on. The high beams do work. One relay seems to work the hi beams and the other the low beams. Swapping relays makes no change.
Also - does the upgrade bypass the dash fuse box? I get a 12v read from one fuse but not the other - ie. they don't seem to be sided as indicated LH, RH. I pull the 10 amp fuse at the upper left and all the lights go out (both hi). I pull the one below it and nothing happens (this one shows no juice - related??)
thanks
thanks
