Hoping that someone can help me. My '03 (190K miles) is having problems.
The symptoms are:
a.) a very loud noise on startup. Like 747 loud. The noise lasted 5-10 seconds and then subsides,
b.) the fan doesn't spin, and I couldn't turn the steering wheel at first, but then as noise goes away, the fan begins to turn and steering comes back.
c.) when I jumped out to look at the engine, the serpentine belt doesn't appear to be moving at all during the noisy period.
So I assume the crankshaft pulley is just slipping along the grooved part of the belt? Can a failure (or impending failure) in one of the other pulleys cause this to happen? Any ideas on how to sleuth it out? Fan spins freely when cold so i think the clutch is ok.
If I take off the belt, is there a way that you can tell if any of the pulleys might be causing it to freeze in the beginning?
TIA
The symptoms are:
TIA
