loud creak after OME
Discussion in '80-Series Tech' started by informationjunky, Aug 6, 2005.
  1. informationjunky
    informationjunky
    3,314
    Albums:
    1
    7
    Jan 30, 2003
    I put on my OME lift last week and I am getting a loud "creaking" sound in the front end when I turn the steering wheel. It started after driving it for several days. I tried listending but cant really pin point it - sounds like its a spring slipping in its seat but I didn't feel it when I had my wife turn wheel while I was under it. any tips or suggestions would be appreciated.
    Thanks
    John
    added info 850J's Front and 863's rear with slee sway bar drop blocks, havn't put castor correction bushing in yet.
  2. T Y L E R
    T Y L E R
    2,597
    6
    Mar 27, 2003
    I had a lesser version after my 850J/863 install .. took about a week I remember to settle down, and not make the odd sound upon turning. Might have been the springs .. though at first I thought it was the front control arms being rubbed.
    TY
  3. beno
    beno Gihee Arakawa Moderator Supporting Vendor GOLD Star
    25,269
    Media:
    382
    Albums:
    29
    23,196
    Aug 28, 2004
    Woodstock, NY, USA
    Definitely put the caster bushings in. They make a world of difference after a lift.
    Also, check the following:
    1. Shock mount points (front and rear, top and bottom).
    2. Check your u-joint connections--look for looseness in axial play (both joints in both drive shafts).
    3. Grab your front drive shaft while the truck is on the ground and try to turn it in either direction. You will get a little play (.25"-~.75") either direction, but you shouldn't get much more than that (at least that is my understnding of driveline play).
    4. Make sure the bolts going into your sway bar drops are secure as well into the captured nuts on the linkage assy.
    5. Make sure you are not getting any rubbing between relay rod (behind the differential) and the front control arms--though this is more an issue after the caster bushings.
    6. Finally, check the TRE ends on both the tie rod and the relay rod.
    This should give you enough PM for awhile. report back your findings.
    Best.
    -onur
    Akron, OH
  4. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    Beno has a good list of checks. My money is that the front shock mounts are not tight enough. Tighten till you get a good bulge in the bushings.
    Cheers,
    Sean
  5. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    679
    Dec 13, 2002
    Knee deep in hookers and gin
    Springs set in the perches properly?
  6. Capt. Jim
    Capt. Jim
    2,215
    3,040
    May 1, 2005
    West Palm Beach, Florida
    Check your panhard bar bushings.
  7. Cruisin'Carolina
    Cruisin'Carolina
    1,435
    10
    Dec 11, 2004
    The Rock
  8. informationjunky
    informationjunky
    3,314
    Albums:
    1
    7
    Jan 30, 2003
    And the winner is....
  9. Capt. Jim
    Capt. Jim
    2,215
    3,040
    May 1, 2005
    Glad that was it. Took me a couple of days to locate that same creak in mine.
  10. Capt. Jim
    Capt. Jim
    2,215
    3,040
    May 1, 2005
    Oh yea, your truck looks good. :)
