I acquired a 91 FJ80 that is 100% stock, unmolested (except for the smog pump removed), rust free, with 150k. Needs new interior and paint. I have never owned an FJ80 and have a ton of questions. My goal right now is to get everything cleaned up and working as stock. Then plan an Old Man Emu 2" lift and ARB bumpers.
1. The truck runs fine but have a code 21 which are the O2 sensors. Ordered 2 Denso and will install this weekend. Anything else I need to do other than bolt them in?
2. Not sure what is normal for these FJ80's but it sounds like a farm tractor running. The rockers are quite loud, is that normal or does it need a valve adjustment? The grommets on the valve cover look like they have never been replaced.
3. Was planning on draining the transmission and add Valvoline Full Synthetic. Do I need to crack the cover pan and replace the filter? Heard it was just metal anyway? How many quarts go back in after draining? Current fluid looks good, but want piece of mind that there is new fluid in there.
4. Planning on power washing the undercarriage or trying to find someone in the Dallas area that does dry ice blasting. Anyone familiar with that process? There is no rust, but some grease accumulation.
5. After cleaning the undercarriage, do you recommend primer and paint? If so, what brand? OR I have heard of Fluid Film, does anyone recommend that stuff?
6. The engine bay needs detailing, but there are so many electronic connections I am afraid to spray water anywhere in there. Suggestions?
7. The rear power windows do not work, nor do the power locks. What should I do to the stock parts to try to revive them, or is it easier to replace?
Thats more than enough questions for now. Give me a day for more!
