- Location
- United States
I am selling a whole slew of FJ40 parts. Most of these came from my 1976 FJ40, but there are also some random parts from other year Fj40's thrown in. All the parts are located in Fort Collins, CO. I am willing to ship most of this stuff at the buyers expense. I can take and send pictures of anything if you are interested in it. Just let me know. So here is the list:
1976 Fresh air vent knob and cable- $5
Random t-case shifter arm with extended linkage attached with heim joints-$10
Random rear upper ambulance door piece for hard top (good shape, with decent paint)- $45
Random headlight pieces (some bulbs and headlight assembly pieces)- $15
2 stock spring pins- $5
1976 Ashtray box (missing interior pop-out part)- $5
1976 Hood hold down clips (sand blasted and ready to paint)- $10
1976 T-case shifter trim ring- $5
1976 Random under hood bracket that held something, but don't know what-$5
1976 1 rear brake light lens in decent shape- $7
Random carb fan from some year FJ40 (minus the mounting bracket), bough off e-bay a while back, never ended up using it. -$15
Misc metal trim ring (maybe from a heater assembly)- $5
1976 Glovebox speaker cover (sand blasted and ready to paint)- $10
1976 Rear heater interior metal hose clamp/brackets (good shape)- $8
1976 Brake master cylinder (worked when pulled)- $20
1976 misc underhood bracket that held something else- $5
Rear bracket that bolts a trailer hitch ball to the rear mounting point on the rear bumper/ frame rail- $10
1976- 1 set of body mount frame horns that hold up the stock running boards- $15
1 random emergency brake drum (year not known)- $10
1976 Stock sheet metal center console- $10
1976 Clutch pedal with bolt- $10
1976 1 set of front seat backs from stock front seats, covers in okay shape. (bottom parts of seats were pretty rotten)- $40
1 Random power brake booster and master cylinder from I think a 1976-78 FJ40, condition unknown- $35 for the complete unit
1976 Clutch master cylinder attached to slave cylinder (working fine when pulled)- $50 for the complete setup
2 random clutch master cylinders, rough shape, years not known- $5 for both
1976 Hardtop fiberglass piece in okay shape- $50
1976 Hardtop metal side pieces with good glass ( the metal is pretty rough, but could be salvaged by a good body person)- $50 per side, or $85 for both sides together
