- Year
- 1996
- Vehicle Model
- 80 Series
- Location
- Los Angeles, California United States
- Mileage
- 164800
- Color
- white
Update: Sold. Thank you for your interest.
Clean, white 80 series Land Cruiser with tan leather interior. Unlocked. Extensive service history and preventative maintenance with documentation. This 80 series has been our weekend driver and family camping truck for ~8 years. Includes 3rd-row seats (drawers currently installed). The truck does not have the F/R lockers. The price is $20k.
Mechanical Condition:
The truck is in excellent running condition. As you will see in the maintenance summary below, we have been aggressive about preventative maintenance ($20k over the past 8 years) to make sure it gets the family out to and back safely. All the baseline work is done, plus major maintenance on valves, valve gaskets, cooling system, exhaust system, braking, bushings, power steering, fuel tank/systems, alternator, starter, distributor cap, spark plugs, etc..
Emissions
Passes CA emissions every year. Great scores because we replaced oxygen sensors and installed a new Toyota factory exhaust system, catalytic converter, muffler, and pipes.
Update: Trucked Smogged on 2/7/23. CA requires the seller to give the buyer a valid smog test.
Interior Condition:
Good interior condition. There is no cracking on the front, rear, or 3rd-row seats. The original carpet and floor mats are in great shape under the WeatherTech. The sale includes 3rd-row seats, but drawers are currently installed. Includes minor interior improvements like LED light upgrades, Covercraft sun shade, factory dash cup holder, Wit’s end console organizer, and removable molle passenger seat back (mainly to protect the seat from our kiddo).
Issues: The driver’s seat operates, but one button is missing. Second-row seats show wear on the backs.
Exterior Condition:
Original paint from 1996. There is some pinstriping on the sides from family camping trips to Mojave and Anza Borrego. The hood and rear hatch struts have all been replaced. I had the passenger side view mirror replaced to fix a common loose mirror issue on the 80s. And we sourced 5 OEM wheels and had a local wheel shop refinish them.
Issues: There is a small dent in the rear bumper and under the sill (under the truck below the passenger door)
Electronics Condition:
The power antenna, automatic locks, rear window defroster, front/rear side windows, and sunroof electronics and motors all work. We replaced the rear window in 2022 to update the defroster heating elements (we use the truck in the winter at Mammoth). Includes an OBDi reader to monitor engine temp, mpg, etc.
Issues: As is typical for 80 series trucks, the green drive light, and a few HVAC lights are burned out.
Upgrades and accessories included:
The truck has modest upgrades that make it more usable for family desert camping and drives to Mammoth:
Maintenance History Summary:
All work done by Toyota Service Center and two Toyota Land Cruiser specialist independent shops SD Trux (San Diego Trux | Independent Toyota and Lexus Service and Repair - https://sdtrux.com) and TLC 4x4 (TLC4x4 - https://www.tlc4x4.com/)
In addition to regular oil changes, here are service details:
I’ve owned the truck from 140k miles. The Ownership History from CarFax will show:
Emissions
Interior Condition:
Exterior Condition:
- Tires: Five BFG KO2s 33s (285/75R16/E 126 R) installed at 142k miles. For the most part, they have been rotated every 3k, including the full-sized spare
- Lift: OME 2” Lift
- Front ARB bumper
- Tint: 3M Ceramic Window Tint in 2022 (helps reduce heat for passengers)
- Rear Drawers: Set of two rear wooden drawers installed (KISS Drawers from Land Shark Outfitters)
- Security System: Prior owner installed a Viper Security system
- Alpine Radio and CB in the double din
- Wits End spare tire leveler (tucks it up for better protection)
- Bolt-on hitch receiver used to carry Bike Rack
- Chains for all 4 tires (we carry 2 during Sierra ski trips) included
- Yakima towers, two bars, and a wind deflector included
- WeatherTech All-Weather Floor Matts for Driver, Passenger, 2nd Row (removed for pictures)
- @140k (2016) : As soon as I bought it, I had SDTrux baseline the truck. The work included new crankshaft seal, Oil pump o-ring, Drive belts, rear main seal, transmission pan & filter screen, transmission fluid, transmission cooler line, torque cover, pesky heater hose, engine coolant flush, oil sending unit, AC compressor, PCV vent hoses, windshield sprayers, and throttle cable assembly
- @143k (2016): After a weekend camping trip, SD Trux did the brakes (new front/rear rotors, brake pads, shims) and serviced the cooling system (replaced the radiator fan clutch). They also repacked the front bearings
- @147k (2018): TLC replaced the bushings (front pan hard, sway bar, lower, trailing arm), brake hoses, e brake shoes, axle seal and bearings, brake booster, valve assembly load sensing, and did a caster correction
- @150k (2019): TLC fixed a leak at the timing cover; we had them replace the power steering pump, water pump, radiator hoses, thermostat, gaskets, idler pulley, starter, Alternator belt, AC belt, fan shroud, and speedi sleeve. The main oil and sub pan were also resealed.
- @150k (2019): TLC replaced Oxygen sensors and installed new Toyota factory exhaust system, catalytic converter, muffler, pipes, and hood latch
- @154k (2020): Toyota Service center serviced the power steering fluid and installed a new OEM alternator, new battery, sparkplugs, side view mirror (decided to fix the zip tie hack), and new battery.
- @157k (2021): Toyota replaced the starter and serviced the valves and valve cover gasket (corrected)
- @157k( 2021): Toyota did an alignment, replaced the front brake pads and rotors, serviced the cooling system, and serviced the differential front and rear.
- @158k (2021): Toytota replaced the fuel tank, gasket, and fuel hose lines
- @160k (2022): Toyota replaced the glass in the rear hatch. We wanted to improve the rear defrost in winter.
- @162k (2022): Toyota replaced EFI fuses, main relay, spark plugs, distributor cap, and rotor
- Owner 1 1995 Villanova, PA @ 62 Miles
- Owner 2 1998 Grapevine, Texas @29k Miles
- Owner 3 2011 Grapevine, Texas @122k Miles -- Serviced at Texas Toyota Grapevine
- Owner 4 2015 Mansfield, Texas @140k Miles. Sold immediately to me.
