Loose Screw
By the way, how did you get off the inside door latch clam shell thingy. I tried to remove that on my Camry (same design) and couldn't figure it out.
There must be a trick.
There is a small screw, remove it and the clam pops out when you pull the door opener. If it is not in right, use a screwdriver at the rear end of the clam. I installed one of them wrong and the door opener got stuck and it was hard to popm the clam off.
kurt
