looking for info or picks on the 203 doubler to auto tranny (1 Viewer)
pbgbottle
Forum Lifer
Cloverdale B.C. Canada
i'm interested in doing this tranny swap into a fj40 or a fj45 , not sure what i want to build . ( fj45 ) . what tranny is recommended turbo 350 , 400 , or the newer ones ,700r -4, 4L60-E , to np203 doubler , anyone have any picks of this setup ? how long is this assembly ? and will it fit in a fj40 ? i probably will stretch the frame and order a fj45 cab from aqualu . any info or links would be appreciated . also any pics of frame stretching ?
Doubler will fit fine on a Th400 or a Th350 as that's what the np203 came on. Then you just use the AA adapter to mount the grb on whatever toyota transfer you want. If I had it over to do again, I'd adapt a 700R4 to the np203, it's a pretty easy deal if you're getting the 700 rebuilt. then put a split case behind that.
Engine moved as far forward as possible, raised up with a 2 inch body lift and rear springs flipped and my rear driveshaft had about 3 inches of tube with a SOA. That was without the needed CV joint or extended slip joint.
Fits amazingly well in a 55. Works amazingly well, too.
http://www.bonnifer.com/Cruiserhome/Th400-NP203-LCtransfercase.htm
just to help
chevy bell is 6 3/8
24.37" TH400
21.75" th350
23.4" 700r4/early 4l60e
21.9" late 4l60e
26" 4l80
10.5" sm420
12" sm465
10.7" np435
18.9" nv4500
12" 4sp LC tranny
3.25 700r4 to 208
6.75 465 to 205
3.5 350 to 205
4.25 465 to 203
4.25ish 400 to 205
1.75 early AA adapter th350 to LC case, close to the short downey one now.
11" face of lc 4 speed case to center of yoke about 1.5 off that for flange
12.25 face to center yoke 205 no adapters
will not post slip yoke, and POS 208 numbers.
5.75 for 203 range box only
some misc doubler numbers
47.5" NV4500, np203, np205
44.75" Sm465, np203, np205
52.25"/56.375" TRII, SM465, np203, np205
46.85"/49.35"/50.35" T400, np203, np205
I am going to shortly have a 5.0/C6/203/split tcase
I should have it together next week somtime..
I'll get pics.
new again?
been awhile since I worked on an fj. Had a 75 with a tpi, th400, lc transfer case, stock axles. Now I own a project '73, carbureted 350, turbo 350, np203, 3/4 ton chevy axles. Want to end up with fuel injection, overdrive, and split transfer case. Just checkin in to see what everyone is doing. Awesome information on this forum
