SOLD Longmont Colorado: 1995 FZJ80 (1 Viewer)
Year
1995
  1. 80 Series
Mileage
200000
New price $12500.
Hey guys decided to sell my 80. Picked it up earlier this year and have not had time to use it.
EDIT: Updated posting with new pictures
Lots of preventative maintenance and Upgrades!
Nightshadow Pearl Blue with grey interior. OBDII. Lots of time and $$$ invested in preventative maintenance and upgrades. I picked up this truck earlier this year and have not had the time to use it so I have decided to sell.
Preventative maintenance:
(Only OEM or better parts used)
OEM Oil pump o-ring
OEM Front Crank seal
PHH done and rear heater bypassed
OEM Heater outlet pipe
Brand New Magnaflor stainless down pipe and front converter
Magnaflow Rear converter
Muffler
OEM Exhaust gaskets
OEM Front and Rear Oxygen Sensors
Clean intake
OEM Toyota Throttle Cable
All new OEM Drive belts
Coolant Flush
OEM Power Steering Pump O-ring
OEM Idler pulleys
Front axle rebuild with all new parts
Front rotors/calipers and pads
Rear rotors/calipers and pads
New wheel bearings and seals
Parking break shoes
All new fluids and filters
New Charcoal canister and hoses
OEM Radiator
OEM Starter
Fusible Links
Hood Struts
Hatch Struts
New Seat Gears
All Fluids updated
Upgrades:
Diffs regeared with 4.88 Yukon Gears
Rear Spartan Locker
Full OME J-spring lift kit
Stainless Steel Slee brakelines
Castor Plates welded on
Slee Drop Blocks and Brackets
315/75/16 Cooper ST MAXX
ARB Diff Breaters
Slee Shortbus Front Bumper
OPOR Sliders
Land Shark KISS Rear Drawers/Sleeping platform
Landtank modified blue-hub fan clutch
Full Weathertech mat set
Front Escape Gear Seat covers and dash pad
Professional undercoating
Bad:
There is some surface rust on the truck, but nothing bad and the frame has be coated so no problems there.
There is also a vibration from the lift, which is common in these trucks. It probably needs some adjustable or extended rear links.
Here is my craigslist post for more details:
PM sent
Best color on an 80! Looks like a great starting point for a build or just rock it as is
Definitely need to get this back to VA! A little high for what I was to spend now, but I'll let you know. I t was definitely maintained!
Do you have the third row seats still? Where is the surface rust - can you post pics?
