I just finished doing the dreaded (to me at least) repair of the brake caliper bolt hole with a helicoil kit. Not that hard of a repair, the worst part was getting the drill started to ream out the hole to the proper size. Until you get about 1/8" in all it wants to do is grab an edge and yank the drill out of your hand. After that the rest of the process is without drama (easy, bordering on pleasant)!
OK, now to my question...
Is it OK to use loctite when installing the bolt?? Seems like I read somewhere that you can't or don't want to, I tried a search with helicoil and loctite and it turned up nothing either way. My instincts tell me a small amount put into the helicoil would run down in between the coil and the threads cut into the hole and another small amount on the bolt would secure it to the "inside" of the coil. My main motivation is a desire to fill gaps in so saltwater won't find its way in there as I live in the rustbelt, so I try to use either loctite or anti-sieze on all my fasteners.
