So, here's my question. 80's series can lock both the front and rear diffs if they have the elec. lockers or an aftermarket locker. And if you put the correct switch in, you can have a selectable center diff as well..... So, with the 60 series transfer case, is it locked (50/50 power split) when it is put into either 4hi or 4lo. I was just wondering if the front axle has no traction, will the back end be able to pull you out? Does my question make sense? If a 60 sreies transfer case does not "lock" from the factory, can it be made to lock? Just a total lack of knowledge here about transfer cases in general.....
Thanks,
Blue 60
Thanks,
Blue 60
