REZARF said:
Mark- Do selectable hubs eliminate the effects of a locker up front? When unlocked don't you "bypass" the locker itself...
Just wondering and still trying to figure out the locker thing. I am installing one (aussie) in the rear this winter (I live in Colorado), and I used to drive a V-8 Camaro in the snow, so breaking loose out back doesnt scare me and I understand it is more driver than machine when it happens.
However, I am still just a bit unsure of the ins and outs of a locker up front. It seems like if I have selectable hubs, then daily driving in 2WD shouldn't be an issue? Is that correct?
Thanks in advance-
CCOME ON PEOPLE.........
a full time locker needs power to the axle for it to lock up. it has springs(in some cases only one big one) that keep the teeth apart when not under loaded.
sooo, when you have a front locker (as i do):
hubs unlocked, pointless
hubs locked Tcase in 2hi: no power to front end=locker unlocked=the two front wheel work seperate from each other.
either of the 4's= power going to front wheels, which means the two wheels are locked togther UNLESS you are not on the gas.
that is why when dealing with a rear locker it is recommended to coast around corners= no power no locker.
i had a rear locker, one winter and it was GONE.
in snow it was fine, great even, but when dealing with packed snow on roads it was wicked scary. ice was a nightmare.
yes there are many types of snow, for mine a rear locker did not work.
my front on the other hand, is a blast.
no gas, turn steering wheel in desired direction, step on gas and that IS where we go.
i'm thinking a rear locker in a 60 would work better......longer is better.
