Locker Questions
MoGas
Central Scrutinizer
GOLD Star
Gold Canyon, AZ
What aftermarket lockers are in use around here in your 80s?
If you could only afford to do one axle at a time, which one would you do first?
Does anyone here use the "lunchbox" lockers (LockRight/Powertrax)? Are they even available for this application?
Thanks,
Dave
lots of threads on lockers in the 80 section. And I think you would start with the rear axel. I perfer ARB's.:flipoff2:
Rear Axle definitley. You can engage the rear locker for the majority of offroad adventures without worrying about it. Always disengage on pavement.
You should only use the front locker on rare ocassions when you need a little more traction in low gear and your not turning. I will turn the front on when I get to a spot I think I need it, and turn it off as soon as I clear the spot.
The lockers tie your two wheel together, when you turn, the front tires have different distances to cover and that puts a lot of strain on the whole front axle.
See the Diffs for Dummies link in the FAQ. It has a pretty good write-up on differentials and lockers.
In my FJ40, I only have a rear locker and it gets me lots of places I couldn't go without one.
You can buty the lunch box, like an Aussie or Lockrite for the 80. I have an aussie in my 40. It will drive different on pavement when you are doing turns.
