Lock-rite Locker
Randfontein South Africa
I’ve got a Lock-rite (Powertrax automatic positive-locking differential) in my Cruiser just wondered what happens if two different size tyres are fitted? Just before anybody shoots me down, different sizes I mean, same make and size. Lets say you get a flat and the spare has 30% tread on and the other 90% there would be a difference in the height (circumference) between the tyres, yes. What could/would happen to the drive train?
I think you would have to have a bigger difference then what there would be with a spare with more tread but still the same "size" as the tire on the opposite end.
The only way I would be worried was if your tires are say 33X12.50s and your spare is a 31X10.50 or smaller.
I think the locker will get confused and lock/unlock more then it needs. Especially if it is at the looser end of the spec. I know I have to have my air pressures darn close, or it squiggles around more. If I have the air pressure bang on, it is pretty much seamless. I would interpolate from this that one worn and one nearly new will be noticed.
When the truck is on the road I rotate my tires fairly regularly due to this, ensuring my spare is included in the rotation (oil changes).
Oh...my experience is with the Ozzy locker, and I am assuming the one you mention functions pretty much the same way.
hth's
gb
if worried, and i wouldn't be, then stick 35psi in the worn one and leave the other at 28 psi to make up the difference...
cheers
wesintl said:
It may also depend on how worn the thrust bushings are. Mine doesn't ratchet around a turn. It just wears the tires more :)
Ya, I think mine is a little on the looser side, and will be checking/tightening it up in the spring...when Poo is back on the road sporting a 13BT (BJ74 is landing this month and donating it's engine:D)
gb
The most automatic lockers alow the outside wheel in a turn, run faster .. always that the secret.
No option to one wheel turn slow than other .. only turno more faster than other one in the same axle.
